I am programming a TMS320F2837xD with Plecs.
I am sending CAN messages using the CAN Tx block.
It seems like the number of such blocks in a model is limited to 16.
When I stream messages on 16 CAN IDs, they all get sent.
I add two more blocks (say on CAN ID 0x20 and 0x21), the messages are not sent
I remove two of my first CAN Tx blocks and 0x20 0x21 are then present.
Haven’t found any limitation mentioned in the documentation though.
Any idea anyone ?
Xavier, what version of PLECS and the C2000 TSP are you using? The transmission rates and step sizes are a possible factor too, so can you please share a test model?
Hi Bryan, sorry for the delay, I am working only part-time on the project where I encountered this problem.
Here is the version I’m on:
And as for the TSP:
CANTest.plecs (383.8 KB)
Attached is a test file.
It works fine as is, i.e: streaming constant float values on CANIDs 0x20-0x2F at 200ms interval.
When I add one message (CANID 0x30), I have no problems executing the program, but I’m only receiving 16 CANIDs, 0x30 is not received. I remove CANID 0x20 and I receive 16 CANIDs 0x21-0x30.
I observed the same result with my receiving software and PCAN-View
Hence my suspicion that I can only use 16 Tx blocks
Hi Xavier, I have resolved this issue and our next C2000 TSP bug fix release will allow you to transmit up to 32 CAN messages. Thank you for the bug report!
Bug is gone in tsp C2000 v 1.10.4
Thanks
