Challenge modeling switch S3 in 4-Port DC-DC Converter on RT Box 1 (Sub-cycle Averaging issue)
Hello everyone,
I am currently working on a HIL simulation of a 4-port DC-DC converter topology (shown in the attached images) using the PLECS RT Box 1 controlled by an external DSP. The system operates with a switching frequency (fsw) of 50kHz.
Current Setup:
  • Hardware: RT Box 1 + External Microcontroller.
  • Time Step: I am achieving a simulation step size of 2us.
  • Inputs: Gate signals are read via the PWM Capture blocks.
The Success:
For switches S_1, S_2, S_4, and S_5, I successfully implemented the Sub-Cycle Average (Hybrid) mode by using the standard “Half-Bridge” and “Boost” power modules from the PLECS component library. This allows me to utilize the high-resolution duty cycle information (float output) from the PWM Capture blocks, maintaining simulation accuracy despite the discrete time step.
The Problem:
I am facing a significant issue modeling switch S_3 (referring to the topology diagram). Due to the specific connection of this switch (in series with a diode connecting the inductor node to the battery), I cannot map it to a standard Half-Bridge or Boost module without encountering algebraic loop errors or unsupported DC source connections within the block logic.
Current Workaround & Failure:
As a temporary solution, I am modeling S_3 using a discrete MOSFET primitive. However, this forces me to convert the high-resolution “PWM Capture” signal (float) into a Boolean signal.
Since my time step is 2us and the period is 20us (50kHz), I only have 10 sample points per cycle. This coarse resolution is causing significant jitter and inaccuracies in the simulation. Consequently, the control loops involving S_3 are failing to stabilize or transition states correctly.
My Question:
Is there a recommended method to implement Sub-Cycle Averaging for a standalone switch like S_3 that doesn’t fit the standard power modules? Or is there a way to configure a generic power module to accept this specific topology without triggering connectivity/loop errors?
Any insights or modeling suggestions would be greatly appreciated.
Thank you!
One cannot develop a sub-cycle average model for a standalone switch. The sub-cycle average models must be derived at the converter level and require certain port characteristics (e.g. for a half-bridge one side must be connected to a positively biased capacitor or DC source and the output terminal connected to an inductor).
Implementing the model with standalone switches will have poor performance as you have identified, since the state of a standalone switch can only be determined once per model step. One could use time-scaling to achieve more simulation steps per switch event, but the model does not run in true real-time.
In short this topology is not supported by the RT Box for real-time simulation.
Thank you for the clarification regarding the standalone switch limitations.
Since my last post, I attempted a workaround by mapping the topology to a 3-Level T-Type Power Module (as shown in the attached screenshot). Physically, the connections appear to fit the structure of the converter I am modeling.
However, I encountered a constraint with the module’s internal logic. It seems the T-Type block enforces specific commutation rules (likely designed for standard inverter operation/interlocks). Specifically, I observed that the module forces a dependency between the switches: the converter only operates as expected if the logic state of the middle switch (my S_3) is consistent with the main leg (S_1). If I attempt to drive them into states that contradict standard T-Type commutation (e.g., trying to keep S_3 open while S_1 is in a specific state), the module overrides my signals or behaves incorrectly, effectively forcing S_3 to follow S_1.
Is there a known method to bypass or disable this internal commutation logic/interlock within the standard Power Modules? Or is there a way to configure a generic power module structure that allows for this specific connection (creating a custom sub-cycle averaged block) without inheriting these pre-defined state constraints?
Any further advice on how to ‘break’ this logic link would be very helpful.
It would be helpful if you could post a model for further analysis including one that shows the expected operation in the switching mode and unexpected operation in sub-cycle average mode.
