Code generation error
When trying to upload code to my STM, I receive this error message.
================ Full Trace ============
“C:/Coder_Targets 5.0/tsp_stm32/tsp_stm32/bin/c2p-gdb/c2p-gdb” load --server-cmd “\“C:/Coder_Targets 5.0/tsp_stm32/tsp_stm32/bin/openocd/bin/openocd\” -s \“C:/Coder_Targets 5.0/tsp_stm32/tsp_stm32/bin/openocd/share/openocd/scripts\” -s \“C:/Coder_Targets 5.0/tsp_stm32/tsp_stm32/templates/openocd\” -f board/st_nucleo_f3_plx.cfg” --server-start-delay 1000 --port 3333 --nvic 0x08000000 ./output_STM32F303RE/ettttttttttt.elf
Error: Unable to connect: A opera��o foi conclu�da com �xito [system:0]
Unable to connect.
Healthy exit.
ettttttttttt.mk:237: recipe for target ‘download’ failed
Open On-Chip Debugger 0.12.0 (2025-09-10-13:51)
Licensed under GNU GPL v2
For bug reports, read
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
none srst_pulls_trst
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 1000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : STLINK V2J46M31 (API v2) VID:PID 0483:374B
Info : Target voltage: 1.933289
Error: init mode failed (unable to connect to the target)
make: *** [download] Error 1
There is likely something wrong with your board’s power supply:
Have you successfully used this board in the past? How are you powering the board? Are you using the NUCLEO-F303RE board (per the error message) or are you using something else? Refer to the section 7.5 of the UM1724 for different voltage supply options.
Another possible cause is missing STLINK drivers. This is the case on some Windows machines. A workaround is to install STM32 Cube IDE (this will also install the necessary drivers).
I am also receiving this type of error.
The interface firmware FAILED to reset/halt the target MCU
