Someone knows what component I have to use to connect the output of a Pulse Generator, like a Label. If I try to connect the Pulse to a Lable, it doesn’t allow me
Hi Fabrixio,
Could you provide a PLECS model to help visualize the issue you are facing?
The Pulse Generator creates a signal in the controls domain, so it must be connected to components that accept controls-domain signals. As a reminder, all controls-domain connections are shown in green.
When you mention a label, are you perhaps using the Electrical Label component?
Hope this helps.
Exactly, is how you described, I was looking for a component that “accepted” the green arrow from the pulse generator. I found “goto” and “from”, and these were the component which I was looking for! Thank you anyway !
