Today with manual and signal switch is only possible to feed an input with two output, how to reverse the direction i order to provide an output to two input
Your question is not clear. Perhaps you can better explain your desires in the context of a model.
The Manual Switch and Switch blocks assign the output signal to one of two inputs of equal width. The Dynamic Signal Selector is another helpful block where you can choose from more than two inputs.
For multiple outputs you use a Demultiplexer, Signal Selector, or perhaps simply “fork” a connection by left clicking on the green wire while holding the control key (⌘ on MacOS).
The signal switches behave differently from an electrical switch since they have a directional component and their behavior is not governed by the physics of an electrical circuit.
There are a handful of approaches for this particular idea, such as having two switches or using the dynamic signal selector to swap the order of signals. Fundamentally, you need to create both a “sin” signal and a “0” signal and switch between them.
