Hi, I’ve been looking deep into the Demo: Flying Capacitor DCDC Converter, to specific, the FCHB Module, which contains the wire selector that connects to source of the lower leg switch
I understand that most wire selectors employ the setting of
Input Witdh: 1 & Output Indices: [ones(1, N)], as is shown in the pic
which means wiring an input with a width of 1 to N output also with a width of 1. This is rather straight in most paralling applications.
However, in the demo mentioned above, the WS in the FCHB module uses the setting of:
Input Witdh: N & Output Indices: [N:-1:1], which is a quite confusing. The following pic depicts what I translated in the setting, pls make sure I’m not mistaken
First, why is the Input width N rather than ones(1,N)? There are N blocks. And why the output indices [N:-1:1] rather than ones(1,N)? Why the first output wire has a width of N and so on? I’m really confused.
Also, rearranging the WS block results in a failed simulation. I simply moved the WS as is shown in the pic followed, could you tell me what really changed?
Thank you!
