I am getting this error while using the thermal simulation model of my inverter circuit.
The device current (-1.13687e-13) is less than the lower limit specified in the thermal description (0).You can turn this error into a warning on the Diagnostics page of the PLECS Simulation Parameters dialog.
I have reduced the input dc. Voltage to 1 volt. After that, I am also getting the same error.
This lower negative current should b rounded off to zero.
I am attaching here the.xml files of the switch and diode, which I have downloaded from the infneon website.
Please help me to resolve this issue.
