How make a variable pulse generator
Hi I need some help about the Pulse Generator.
I want to use one pulse generator block, start with a 0.5 duty cycle wave, and in another period the duty cycle change for 0.8 for example, but using only one block in the same pulse, I will put some image example below.
Is the period consistent for all pulses?
If so you can simply use a Triangular Wave Generator with a “Duty cycle” of 1 (creating a saw-tooth waveform with positive slope) and a comparator block (comparing the Triangular Wave Generator output with your desired period).
Yes, I understand your circuit, but I want different period in some pulses, like 0.5 duty cycle pulses and after some periods the duty cycle change to a 0.8 duty cycle.
If you are changing the period and duty cycle then you can use the “Variable Frequency PWM” block. See the simple example attached.
variable_period_variable_duty.plecs (7.81 KB)
