Hi
I’m referring Buck Converter with Parameter Sweep example
I would like to export only the last periods of waveforms, to do that I generate a signal trig and enable a datacapture block. However it export all the signals long.
Instead using a file method it works (see datacapture block)
how can I do? thanks
boost_NIBB_coupled_plot.plecs (114 KB)
I don’t fully understand the question as it appears that you are successfully exporting the data, starting only after a pre-specified period of time using a triggered subsystem. Are you expecting something different? I have attached a modified version of the demo model your refer to that shows the same method to do this.
Boost_save_to_file_upon_trigger.plecs (15.3 KB)
