How to generate unipolar PWM for boost converter using C-script?
Can someone share the sample code of generating a simple unipolar PWM for conventional boost converter?
Also, what could be done to make it a PWM for multiphase boost converter where each PWM is phase shifted.
Thank you.
Have you looked at the demo model included in PLECS called “Inverter with C-Script-Based PWM Modulator”? You can view and modify the C-Script based modulator for your purpose.
