I am working with RT Box and I have a question about the PWM Capture block:
I want to use two PWM capture signals that are coming in as 5V differential signals, and feed them to the gate drive. Is there a recommended way to make this work in RT Box?
When I connect additional logic blocks (e.g., Comparator or SR Flip-Flop) after the PWM Capture output, I get errors during simulation/code generation. Is there a specific reason for this limitation, or an alternative way to process the PWM Capture signals with logic?
I would appreciate any guidance or example setup for handling differential PWM signals correctly and for combining PWM Capture with logic blocks inside RT Box.
Thanks in advance!
