I want to use the terminator block in the plecs library, I cannot find it. I check matblab simulink, there is a terminator in the component library, please which component can I use as terminator in plecs?
The Terminator block in Simulink is used to prevent error/warning messages for blocks whose output ports do not connect to other blocks. PLECS allows you to have unconnected output ports and does not generate similar warnings/errors. Therefore there’s no need for an equivalent component in PLECS.
