I am currently working on a three-phase AC/DC rectifier simulation in PLECS and I am observing a behavior that I do not fully understand when introducing a transformer between the AC source and the diode bridge rectifier.
I would appreciate your help in understanding whether this behavior is physically correct, caused by transformer parameterization, or due to an incorrect modeling approach in PLECS.
System Description
I built a standard three-phase uncontrolled diode rectifier feeding an RL DC load.
The system consists of:
Three-phase AC voltage source
Three-phase transformer
Six-pulse diode bridge rectifier
DC-side inductive load (R-L)
The DC current is nearly continuous because of the output inductance.
Observed Behavior
WITHOUT the transformer
When the rectifier is connected directly to the ideal three-phase source:
The AC input voltages are sinusoidal
The AC input currents have the expected 120° conduction shape
The DC output voltage has the expected 6-pulse ripple
The DC current is smooth and continuous
This behavior appears correct and expected.
WITH the transformer inserted
After adding the transformer between the source and the rectifier, I observe the following:
1. Secondary line-to-line voltages become highly distorted
I am measuring:
Vab
Vbc
Vca
on the transformer secondary side.
Instead of remaining approximately sinusoidal with only commutation notches, the waveforms become almost “three-level” or “six-step” shaped.
The line voltages appear strongly clipped and flattened.
2. Input currents become almost sinusoidal
At the same time, the transformer secondary/input currents become surprisingly smooth and nearly sinusoidal.
This is unexpected to me because for a standard 6-pulse diode rectifier I would normally expect:
nearly sinusoidal voltages
strongly non-sinusoidal line currents with 120° conduction intervals
However, in my simulation I obtain almost the opposite behavior.
My Questions
I would like to know:
Is this behavior physically correct for a transformer-fed 6-pulse diode rectifier?
Could this be caused by:
excessive leakage inductance,
incorrect magnetizing inductance,
or an incorrect measurement location?
In PLECS, are the transformer terminal voltages measured:
before leakage impedance,
or after leakage impedance?
Could the transformer leakage inductance alone realistically cause:
nearly sinusoidal AC currents,
and highly distorted line-to-line secondary voltages?
What would be considered reasonable values for:
leakage inductance,
coupling coefficient,
or short-circuit impedance
for a realistic transformer model in this type of simulation?
Is there a recommended way in PLECS to model a “nearly ideal” transformer for validating rectifier behavior?
Additional Notes
The transformer secondary voltages being measured are definitely line-to-line voltages, not phase-to-neutral voltages.
The DC-side inductance is relatively large, producing continuous conduction mode.
No active switching devices are used — only a diode bridge.
The issue only appears after inserting the transformer.
The rectifier behavior without the transformer looks normal.
What I Expected
I expected:
- line-to-line secondary voltages to remain mostly sinusoidal,
with only small commutation notches,
and:
- line currents to retain the classical 120° conduction shape.
Instead, I obtained:
highly distorted secondary voltages,
and almost sinusoidal line currents.
Goal
I am trying to determine whether:
the simulation is actually physically correct,
or if my transformer model is introducing excessive impedance or incorrect dynamics.
Any guidance regarding:
transformer modeling best practices,
parameter selection,
or measurement interpretation in PLECS
would be extremely appreciated.
Thank you very much for your time and support.
Without Tranformer :
With transformer
below is the simulated file (I used the blockset version with matlab)
projet1.slx (93.4 KB)
