I have problems simulating thermal performance for two SiC-MosFETS from WOLFSPEED C2M0080170P and c3m0065090d. I have defined the performance for positive and negative currents, voltages and temperatures. Still this error is popping up. Did I do something wrong with the thermal description?? See attached.
It appears that these are not the official thermal descriptions provided by the manufacturer on their website. We would recommend that you use those models if possible.
It is also not easy to fully diagnose the issue without having your circuit model that shows the error message. I suspect, however, the issue is a numerical one. For example, with the thermal description you attached for C2M0080170P, the Conduction Loss current axis has a value of 6.133300000000001e-15. You should change this to 0. Also, the datapoint at 25C and 10A is 0.8436100000000001. This should probably be truncated to 0.84361. Further, your thermal impedance coefficients have a complexity that may lead to a numerically stiff system.
I have changed what you pointed out above (the 6e-15 was an error - obviously should be zero). But this does not solve my issue. It seems my error is with C3x description, because if I don’t attach any thermal description to this part my circuit runs fine. I have attached my model. The error is
Again, this is a numerical issue due to small roundoff errors created by not fully forcing the positive/negative conduction inflection point to be at zero current/zero voltage. Please change the 0A column voltage values for the conduction losses to all be 0V.
