I was working on dual active bridge simulation in PLECS and I came across the demo model which is available in example section. I would require some assistance in understanding the control strategy in phase shift modulation. I have understood the theory behind the application of phase shift modulation between the primary and secondary bridges; however, the block diagram below used for the simulation is unclear to me. Although I know the function of each of the blocks used below, I am unable to understand how they are functioning together particularly in this block diagram. It would be great help if you could throw some light on this.
Thank You!
First, I’ll note there is a “Variable Phase PWM” block in the PLECS library. The underlying implementation is a C-Script, so it may be more difficult to understand, but the block is better documented than the phase shift PWM in the DAB demo model. The sampling behavior also better aligns with a digital phase-shift controller. See the component help for additional information.
Regarding the model you’re referencing, I would suggest adding additional scopes to analyze the block behavior. Please see the attached model which I used to generate the annotated scope capture below.
phaseshiftpwm.plecs (26.9 KB)
The block input is between -1 and +1 resulting in a phase shift of -180 or +180 degrees, respectively, between the primary and secondary gate signals. The output signals have a fixed duty cycle of 50%. One can see the “On carrier” and “Off carrier” waveforms are phase shifted 180 degrees from each other. This ensures the duty cycle is set to 50%.
The “Mpri” value (0.5 - m*0.25) sets the compare for when the primary turn-on and turn-off events happens. The turn-on is when (“On carrier” - “Mpri”) transitions from negative to positive, which generates a hit crossing event in the PLECS Solver. This sets the SR flip-flop for “G_pri” to a logical true output. The turn-off is when (“Off carrier” - “Mpri”) transitions from negative to positive, resetting the SR flip-flop for “G_pri” to a logical false output.
The “Msec” value (0.5 + m*0.25) value sets the behavior for the secondary turn on, which has an identical logic scheme but with a different compare value. Since the primary and secondary have the same carrier waveform, adjusting the compare values of both the primary and secondary results in a phase shift. Centering the compare values to 0.5 makes it easier to have both positive and negative phase shifts.
Thank you so much for the detailed analysis. This is really helpful!
