I have created a group of blocks to calculate the power factor. But when I run it, the simulation ends with a divition by zero error. I can go and change the setting that turns division by zero into a warning, but I don’t want to do that, because under other conditions I want this to be an error.
I think the division by zero is caused by the first data point in the simulation. So is there a way to tell PLECS to skip over the first data point and start analyzing from the second and on? Attached is the circuit.
