Is it possible to save a complete simulation, such that you can pull up all scope plots at a later date? Or can this only be done on a scope by scope basis?
No, unfortunately this is not possible- it does need to be done on a scope by scope basis. Alternatively you can route all of the signals of interest to a To File block and then later load those into a set of Lookup Table blocks whose outputs can be plotted in a Scope(s). Please see https://forum.plexim.com/11/is-it-possible-to-import-waveform-data-into-plecs for an example of the latter.
