SPICE Model – Junction Temperature Measurement in PLECS
I am currently simulating a single-phase inverter using GaN switches with Spice PLECS. The GaN SPICE model I am using includes five thermal/electrical probes.
Has anyone here performed simulations with similar models?
I would like to understand the correct setup in PLECS for measuring junction temperature (Tj) and case temperature (Tc). At the moment, I am getting very unusual results for the junction temperature when observing Tj in the scope.
I would appreciate any guidance regarding:
  • Proper thermal network configuration
  • Correct connection of thermal nodes
  • Recommended settings for realistic junction temperature results
Thank you in advance for your help.
Yasser
Hi Yasser,
It would be helpful if you could share a PLECS model that demonstrates the issue. That would make it easier to understand the challenge you are facing and provide more specific guidance.
