The internal oscillator cannot be greater than 194 MHz, which is different from that of tutorial video
Error(s) during execution of code generation method ‘Finalize’ in 28379_test_Sep_4_dac_v3/Controller:Excessive system clock setting for internal oscillator. Must not be greater than 194 MHz.
Below is the screenshot of tutorial video,in which system clock can be set as 200MHZ
Below is my own screenshot ,in which the error occurs.
So maybe it’s a problem of plecs version or what???
28379_test_Sep_4_dac_v3.plecs (10.4 KB)
Maybe 190MHZ is perfect enough,because the oscillator frequency is 10MHZ.
The maximum frequency of the 28379D when using the internal oscillator is 194 MHz. The 200 MHz limit is if you are using an external oscillator circuit, which is not available on unmodified LaunchPad boards. Refer to note (2) in this section of the 28379D datasheet.
The video was published before the TSP was updated to reflect this limit.
Thank U so much ,I cannot express my gratitudes!!!
