I am currently working on a simulation in the PLECS Blockset and require the thermal model .xml files for the following MOSFETs:
- STB120NF10T4
- STP120NF10
- STW120NF10
These models are crucial for accurately simulating thermal behavior and assessing efficiency in my application. I would appreciate it if you could provide the corresponding PLECS-compatible thermal model files or let me know where I can download them.
Thank you very much for your assistance.
Fazal,
PhD Student
Hello Fazal,
There are no publicly available thermal models for these devices. There is the Thermal Import Wizard to convert graphs and parameters from device datasheets into PLECS thermal models. Here is a video tutorial on the topic.
A quick look at the datasheet for those devices shows that there is no switching loss data. You can only extract the conduction losses and thermal impedance curves. Please refer to this post for an example of using formulas to estimate the switching losses in the absence of additional information based on rise time, fall time, reverse recovery charge, etc. from the datasheet tables. Note the caveats described in the post as well.
Bryan
