I did the nonlinearity simulation of high frequency transformer in ansys maxwell designed of power converter, and i want to tested with full converter circuit including the switches and their details. It is possible to represent the transformer using lookup table in plecs based on the imported data from ansys maxwell, or are there and tool that can be used to integrate between plecs circuit and ansys transformer model.
Depending on your intended output, you might consider using a Linear Transformer and adapting the circuit accordingly. To do this, right-click on the component and choose Subsystem > Break library link, then again Subsystem > Look under mask. For instance, you could replace the magnetizing inductance, currently modeled as an ideal inductor, with a Saturable Inductor.
If you also have access to Twin Builder, you could consider exporting an FMU as Model Exchange by first generating a reduced-order model (ROM) in Maxwell and then exporting it from Twin Builder.
If you need more detailed guidance, please share the available data from Maxwell or any export options you have.
