I want a way to import 1D look up table in a CSV file and use it as 1D-Table data source. The data is not time stamped or time dependent. Right now the only way to use 1D lookup table is to manually type in data in the block which is inefficient if the lookup table is even slightly large. Is there a way to import external csv file as vector of x and f(x)?
I am aware that Plecs 4.4 has a From File block to import timestamped 1D lookup table to the simulation. I don’t think that is the solution to the issue I am facing.
.Plecs Standalone 4.43 (64 bit), Windows 10.0.17763
