Customized PWM/ Waveform
How can I generate waveforms like these? I am working on a Multilevel Buck Converter (aka FCML Buck/ Switched Capacitor Buck). The period is 10us. Each switch is ON for 2us. I have attached a picture of the circuit. Please share some valuable insight!
Use two pulse generators with proper phase shift and OR them together:
doublePulseGen.plecs (6.0 KB)
Thank you so much. This is exactly what I was looking for. In your doublePulseGen.plecs file, could you please explain how you generated four pulses using only two pulse generators?
Hi Arnob,
Oliver has vectorized the pulse generator by setting the “Phase delay” parameter to be a vector. See below:
By setting the phase delay as a 4 element array, the pulse generator will generate 4 pulses each with the associated phase delay determined by the index.
Hope this helps!
Hello Munadir,
Thank you so much for the explanation. I am a new PLECS user. One thing I am confused about is that I need to drive 4 MOSFETs. But here, all 4 gate driving pulses are coming from one source. My question is, how can I drive 4 MOSFETs with the same PWM sequences?
Hi Arnob, as a new user I would recommend a few things to help you get up and running.
  • PLECS tutorials: while these are a little dated they are still a fantastic resource for new users to get up and running. Tutorials | Plexim has a whole list of tutorials for all of our products but since you are a new user I would stick with base PLECS for now. I would at the minimum go through “PLECS: Introduction to PLECS Standalone”, “PLECS: Modeling a Switched-Mode Power Supply”, and “PLECS: Thermal Simulation of a Buck-Converter
  • Video tutorials: on our Youtube page you will find a host of useful videos to help you get up and running with PLECS. As a new user I would recommend starting with the playlist “PLECS tutorial videos”.
Now to get back to your question of how to drive individual MOSFETs. As I mentioned, the solution Olivers provided vectorizes the pulse generator using the phase delay. So the output of the Pulse generator is 4 signals lumped into one line. To get the individual signals out you can use a demultiplexer that converts the vectorized gate signal into individual gate pulses that you can then send to your MOSFETS. As an example, have a look at the “2-Level MOSFET Conv.” PLECS component. If you right click on the component, expand the Subsystem menu option and select Look Under Mask you will see an example.
Hope this helps!
