Hello
I am currently working with the RT-Box and trying to control a voltage source inverter from it. I have been using the PWM out block for the initial testing of the inverter, which have enabled me to run dead times of 100ns with 200khz switching frequency.
Now i am trying to do the same with the specevector PWM block, the problem lies in that to do so i need to use the digital out block and the blanking time block, but to get the same blanking time and switching frequency as in the initial testing the RT-Box step size must be 1e-7, which is not possible.
Is it simply not possible or am i looking at the problem in a wrong way?
Best regard
Tobias T. Strate
