Dear specialist:
Today I update the version of plecs as well as the version of c2000 tool, and I tried to build the plecs model, but I found out that the launchpad cannot be build as normal, the error occured as:
So how to solve the problem since it indicates that my dsp controller is reset? I toggled the reset button of the DSP controller but still it doesn’t work.
Error in build step #3 (Make): Make process exited with code 2:
“C:/ti/uniflash_6.0.0/dslite.bat” --flash --config=.\output_TI2837xS\uniflash.ccxml .\output_TI2837xS\Controller.out
Executing the following command:
> “C: i\uniflash_6.0.0\deskdb\content\TICloudAgent\win\ccs_base\DebugServer\bin\DSLite” flash --flash --config=.\output_TI2837xS\uniflash.ccxml .\output_TI2837xS\Controller.out
For more details and examples, please refer to the UniFlash Quick Start guide.
error: C28xx_CPU1: Trouble Reading Register PC: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: Trouble Writing Memory Block at 0x5f412 on Page 1 of Length 0x1: (Error -1137 @ 0x5F413) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: GEL: Error while executing OnTargetConnect(): Target failed to write 0x0005F412@Data
at *((int *) 0x5F412)=0x000F [f28377s.gel:77]
at OnTargetConnect()
error: C28xx_CPU1: Trouble Writing Memory Block at 0x5fb00 on Page 0 of Length 0x2: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: Error occurred during flash operation: Target failed to write 0x5FB00@Program
error: C28xx_CPU1: Trouble Writing Memory Block at 0x5f800 on Page 1 of Length 0x2: (Error -1137 @ 0x5F802) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: Error occurred during flash operation: Target failed to write 0x0005F800@Data
error: C28xx_CPU1: Error initializing flash programming: Interface returned from dll, but flash is not available on this device.
error: C28xx_CPU1: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: Trouble Writing Memory Block at 0x7029 on Page 1 of Length 0x1: (Error -1137 @ 0x702A) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: GEL: Error while executing OnReset(-1): Target failed to write 0x00007029@Data
at *((int *) 0x7029)=0x68 [f28377s.gel:27]
at OnReset(-(1))
error: C28xx_CPU1: GEL: Error calling OnPreFileLoaded(): Reset failed: retcode=-1
error: C28xx_CPU1: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x2: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.1.1.00002)
error: C28xx_CPU1: File Loader: Verification failed: Target failed to write 0x00000@Program
Controller.mk:147: recipe for target ‘download’ failed
Failed: File: .\output_TI2837xS\Controller.out: Load failed.
make: *** [download] Error 1
