Parameter sweep 3 phase voltage
Hello Guys,
how i can parametersweep a 3 phase voltage with phase shift(0,120grad and 240 grad)?
thanks in advance
Please see the demo model included with PLECS “Buck Converter with Parameter Sweep” where an inductance value is swept. With a 3 phase voltage source you can parameterize the magnitude, frequency, and offset values by assigning variables that you then change the values for via a script, for example. In PLECS Blockset, you can run a MATLAB script, and in PLECS Standalone you can either use an internal Simulation Script (video: https://www.plexim.com/support/videos/simulation-scripting-standalone), or externally via the XML-RPC protocol, such as to use Python as your scripting environment, for example.
Good luck,
