Parameter Sweep
Hello PLECS Team,
I need to use a Parameter sweep for Switching frequency of the Inverter.
I tried as mentioned per this video Buck Converter with Parameter Sweep
But the sweep results are not appearing on the scope individually.
Recommending some insights…
Thanks in advance.
Hi YadalaTejasri, could you upload the model with the issue you are struggling with. It would make it easier to point you in the right direction.
