Power Factor
Hello, I’ve been looking for a block that measures Power Factor, and I haven’t found anything. Is there a block that works for it?
Alberto,
The PLECS component library does not include a component to measure power factor.
Assuming you are interested in three-phase systems, attached is a simple model to calculate the power factor that works well for balanced, three-phase systems with low harmonics. You can find similar calculations for P & Q in the “Microgrid in Island Operation” and “Windpower System with Permanent Magnet Synchronous Generator” demo models.
You should note this is one of many possible implementations of a power measurement block. For example, the calculation could be performed in different reference frames or using sequence decomposition. There also are different possible sign conventions for leading/lagging power. The calculation you ultimately choose should depend on the characteristics of your application, but this should get you started.
Bryan
power_factor_measurement.plecs (21.8 KB)
