My name is Eunwoo Lee from South Korea. We are connecting an RT Box 3 and a TMS320F28388D board over EtherCAT.
Setup - Master: Beckhoff C6030, TwinCAT 3 - RT Box 3: TSP 4.0.8, EtherCAT block (CoE) - DSP board: F28388D on-chip EtherCAT slave controller (SSC 5.13), TI DP83822 PHYs, Auto-MDIX enabled
Each device works alone with the IPC, and two DSP boards chained together also work.
However, the DSP board and the RT Box never link to each other, in either order (IPC-DSP-RTBox or IPC-RTBox-DSP).
Two different DSP boards show the same result, and changing cables or RT Box ports does not help.
On the DSP side, auto-negotiation pages are exchanged (the RT Box advertises 100BASE-TX full duplex and acknowledges), but the link is never established (BMSR = 0x7849).
In the reverse order, the RT Box port 1 link goes up and down repeatedly.
Could you tell us which PHY the RT Box 3 uses on its EtherCAT ports, and whether any of its link settings can be adjusted?
We would also appreciate knowing if any compatibility issues with TI DP83822 PHYs have been reported.
Eunwoo Lee
