Scope Parameters
Hello ,
I want to measure duty cycle as automatically with scope but ı cant is there any solution about this topic?
Best Regards.
Hi Enes,
well there are different ways in which you can do this, you can use the cursors to give you the average of the PWM signal in a switching period. Or you can pass the PWM through a “periodic average” block (setting the average period as the switching period), and then feed it to a scope.
See the attached example.
ı understand , thank you very much.
Best regards.
