Hello all,
I am currently working on simulating a simplified full-bridge LLC circuit.
Something I noticed in the simulation setting with the HIL model is that the steady-state final Vmout of the circuit has a difference of around 4Volt when I apply/don’t apply the 1e-9 parasitic capacitance in parallel with the diode.
Thus, my question is are the 4 Volt difference something expected in a state-space simulation engine? Or is there any addition parameters that I should setup to get a more accurate HIL model output?
I have also attached
Full-bridge-llc-simplified-hil.plecs (34.0 KB)
Full-bridge-llc-simplified-hil-with-capacitorx30.plecs (36.1 KB)
the plec circuit file if that helps.
Many thanks !
