Warburg Impedance & Constant Phase Elements (CPE)
I am trying to model the electrochemical impedance behavior of a lead-acid battery to test one of our products against the requirements of IEEE Std 2405 Section 5.8: Dynamic Response.
Typical equivalent circuit models that use passive RLC approximations have poor accuracy with respect to impedance analysis because they do not reflect the diffusive characteristic of the electrolyte. (See https://doi.org/10.3390/en11010118)
The inclusion of a constant phase element improves the accuracy greatly. My problem is that the CPE requires a fractional exponent in the s-domain and a fractional derivative in the time domain.
The existing PLECS transfer function does not permit fractional exponents. Is there another way I could represent this element?
PLECS doesn’t natively support fractional time-domain derivatives. After a bit of research, it seems like the most common approach is to approximate the Constant Phase Element (CPE) with a Oustaloup Recursive Approximation.
Here’s the PLECS model implementing the theory below: CPE_example.plecs (21.3 KB)
A CPE has impedance:
Z(s) = \frac{1}{C_\alpha \, s^\alpha}, \quad 0 < \alpha < 1
where C_\alpha is the CPE coefficient and \alpha is the fractional exponent. For \alpha = 1 this reduces to a pure capacitor; \alpha = 0 gives a pure resistor R = 1/C_\alpha.
The ORA approximates s^\alpha as a rational transfer function over a finite frequency band [\omega_b, \omega_h] using N pole-zero pairs:
s^\alpha \approx \omega_h^\alpha \prod_{k=1}^{N} \frac{s + z_k}{s + p_k}
The zeros and poles are log-spaced across the band:
z_k = \omega_b \left(\frac{\omega_h}{\omega_b}\right)^{\frac{2k-1-\alpha}{2N}}, \qquad p_k = \omega_b \left(\frac{\omega_h}{\omega_b}\right)^{\frac{2k-1+\alpha}{2N}}
with z_k < p_k for all k, alternating in pairs across the band.
The CPE impedance approximation follows directly:
Z(s) \approx K \prod_{k=1}^{N} \frac{s + p_k}{s + z_k}, \qquad K = \frac{1}{C_\alpha \, \omega_h^\alpha}
Order selection: N = 5 or N = 7 is a typical order, with higher order being a better fit. One can also extend the frequency match band for a better fit within a smaller frequency sub-interval.
State-Space Realisation
Cascading N first-order sections yields an N-th order state-space system
\dot{x} = Ax + Bu\\ y = Cx + Du
with input u = I (current) and output y = V (voltage).
The matrices have a closed-form lower-triangular structure:
A_{ij} = \begin{cases} -z_i & i = j \\ p_j - z_j & i > j \\ 0 & i < j \end{cases}
B = \mathbf{1}_N, \qquad C = K\begin{bmatrix} p_1 - z_1 & \cdots & p_N - z_N \end{bmatrix}, \qquad D = K
Note that C directly mirrors the sub-diagonal structure of A (scaled by K), so only the pole/zero pairs and K are needed to fully specify the system.
PLECS Implementation
The model uses a State Space block with matrices A, B, C, D as computed above. The block models the CPE as a voltage-controlled current relationship:
  • Input u: current through the CPE branch [A]
  • Output y: voltage across the CPE [V]
The output is driven via a controlled voltage source. Initial conditions x(0) = 0 are appropriate for a discharged element but could be added to the model. Given the voltage source implementation will be some restrictions on what elements can be connected in parallel with the component (state source dependency).
Results
Here’s the theoretical match when \alpha is 0.5. Note the approximation is only valid within [F_\text{min},\, F_\text{max}]. Choose this range to cover all significant spectral content of the excitation signal. In this case the range was 1 to 10 kHz. This is generated by the model initialization commands.
Here’s the results comparing the case where \alpha = 1 between the CPE element and a capacitor:
Thank you for the quick reply and example model! I will test this to see how it behaves for my use case.
