Agent rules the world ![]()
Hi @yang, thanks for the question!
Itās an interesting idea. The term AI agent can mean many different things (from simple assistants that help with documentation/search to more autonomous systems that help execute workflows), so Iām curious what you had in mind when you wrote it? Are you thinking of:
- something that helps navigate PLECS documentation / examples?
- a tool that could help automate simulation tasks or parameter sweeps?
- something that could generate or suggest models / scripts for common tasks?
- or something else entirely?
Just trying to understand the use-case youāre picturing.
Hi, thanks for following up!
What I have in mind is an agent that can actively participate in the simulation workflow. Ideally, Iād like to be able to describe a converter in natural language and have it built automaticallyāfor example, ābuild a peak current-mode controlled buck converter with the following LC parametersā¦ā and then run parameter sweeps using natural language commands. That way, I can tightly integrate the design process with simulation without manually running each case to compare results.
Iād also like the agent to assist in writing simulation scriptsāfor instance, generating a positive/negative sequence impedance sweep script for a three-phase inverter to perform custom advanced testing.
Also, I hope the agent can take part in the entire HIL testing process. After the model is built, the agent would automatically deploy it to the HIL system, run the desired test sequence, and manage the whole process without human intervention.
Finally, Iāve been thinking about whether PIL (Processor-in-the-Loop) could make a comeback. In the context of AI-powered automated testing, which matters moreāreal-time performance or accuracy? It seems to me that PIL could potentially deliver more accurate results than HIL, and with AI running tests 24/7 without human supervision, real-time constraints become less of a concern.
These are some of the ideas Iāve been thinking aboutāhope they donāt sound too naive!
Thank you for your interesting insight. I agree that some of the mentioned use cases are predestined for some sort of AI support, although I am not entirely sure whether this is something PLECS itself should provide. Letās go through it step by step.
The main question that arises here is: where should PLECS obtain the data for training such a system? PLECS provides demo models, but these are far from representing real, fully implemented industrial circuits. Even if all openly available schematics were used for training, the most sophisticated and optimized designs are typically not open access.
Furthermore, if the model is trained only on already available circuits, the output will essentially be an average of existing solutions. In that case, it is questionable whether such a system could truly surpass the current state of the art.
In my opinion, this is rather a task for individual companies. They could develop an internal agent trained on their own past designs. This would help engineers implement previously successful concepts and avoid repeating mistakes made in earlier projects.
ā¦and then run parameter sweeps using natural language commands. That way, I can tightly integrate the design process with simulation without manually running each case to compare results.
PLECS and the RT Box already provide APIs via XML-RPC or JSON-RPC, which can be accessed, for example, using Python. Personally, I trained an LLM on the PLECS documentation (PDF Version or Online Version). Since modern LLMs are very strong at generating Python code, this significantly accelerates scripting and automation tasks.
In addition, you can use an LLM tool that is already approved and verified within your company, instead of relying on a built-in solution inside PLECS.
In general, I would argue that PLECS should focus on providing a powerful and comprehensive API that allows users to define and control simulations programmatically. Many functions are already accessible, but some capabilities are still missing (for example, drawing a circuit entirely through commands).
Adding a built-in AI agent directly into PLECS, on the other hand, is something I consider rather unlikely.
Hi, thanks for the reply! Based on my current understanding of LLMs, Iām on the same page as you.
Regarding your point about training an LLM on the PLECS documentationāhow did you go about that? Could you give me a high-level overview of the process?
I hope to join your discussion. I have used both the XML-RPC and JSON-RPC interfacesāthe former with Python and the latter with Matlabāto extract data for training corresponding neural network models. However, I encountered a common issue: as the number of samples increases, the time required to obtain results from single/batch simulations becomes quite long (on a personal PC). My solution was to develop my own time-domain model of the converter. Based on this, I have a few questions Iād like to consult about:
How can I use the LLM you have trained? I couldnāt find this in the user manual.
For purposes requiring batch data training, could Plecs provide a simplified simulation model to speed up the process? Alternatively, could it offer standalone loss or magnetic component modules? Users could then build their own time-domain models and call Plecsā loss/magnetic modules to obtain the necessary data.
Given the powerful capabilities of current models, could Plecs develop a dedicated model to answer user questions and help them set up simulation models more quickly? I understand this would involve costs and could be offered as a separately subscribable feature.
These are some of my thoughts, which I wanted to share with you all.
So far, itās quite simple. We created a bot in ChatGPT and uploaded the documentation as a PDF. Since the bot is aware of the documentation, finding the correct commands is much faster, and it becomes even more efficient as you use it, learning from your previous code.
I am extremely weary about AI but agree 100% with your analysis. What I think you describe is an expertly designed introspective and user-programmable interface that drives a superb extensible simulation engine. The latter part is of course already there, the first part just needs some real, not artificial intelligence. The main problem might be that the introspective and extensibility parts clash with the objectives of commercial programs. In principle FMU solves this problem but what I have seen to date is that it buries the basic functionality under layers of formal canine excretion.
