Hello, I would like to ask about an issue with the PLECS RT Box PWM blocks.
- PLECS version: 5.0.6
- RT Box TSP/library version: 4.0.7
- Target device: PLECS RT Box 3
- PWM Out: 12 channels, 5 kHz
- PWM Capture: 12 channels, Sub-cycle average
- Model sample time: 5 μs
With identical parameter settings:
- Offline simulation works correctly when using the embedded TargetCode PWM Out/PWM Capture blocks without the blue library-link indicator. (model 1)
- When using PLECSRTBoxLib/PWM Out1 and PWM Capture1 with the blue library-link indicator, the model runs, but the PWM Capture output remains zero. (model 2)
I have confirmed that:
- The duty-cycle signals at the PWM Out input are valid.
- The offline loopback connection from PWM Out to PWM Capture is present at the top level.
- Both signals have a width of 12.
- No related fatal diagnostic errors are reported.
Could you please clarify:
- Is this a compatibility issue between PLECS 5.0.6 and RT Box TSP 4.0.7?
- Do the library-linked blocks require any additional configuration for offline simulation?
- Could this issue affect the actual PWM output and capture functions on the RT Box 3?
- Would you recommend upgrading PLECS/TSP or continuing to use the embedded TargetCode blocks?
model1.plecs (769.0 KB)
model2.plecs (615.5 KB)
