I am generating C code for my 28069 launchpad ,it works perfectly when I using it directly but the error occurs when I want to generate the code in CCS project ,the error message is as follows:
So is the code I generate too big for memory of my launchpad?
Description Resource Path Location Type
gmake: Target ‘all’ not remade because of errors. dev_28069_Dec__6_v1 C/C++ Problem
IQTABLES memory range has already been F28069.cmd /dev_28069_Dec__6_v1/app line 37 C/C++ Problem
IQTABLES memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 37 C/C++ Problem
IQTABLES2 memory range has already been F28069.cmd /dev_28069_Dec__6_v1/app line 38 C/C++ Problem
IQTABLES2 memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 38 C/C++ Problem
IQTABLES3 memory range has already been F28069.cmd /dev_28069_Dec__6_v1/app line 39 C/C++ Problem
IQTABLES3 memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 39 C/C++ Problem
program will not fit into available 28069_RAM_lnk.cmd /dev_28069_Dec__6_v1 line 121 C/C++ Problem
RAML memory range overlaps existing memory F28069.cmd /dev_28069_Dec__6_v1/app line 45 C/C++ Problem
RAML8_RSVD1 memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 55 C/C++ Problem
RAML8_RSVD2 memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 56 C/C++ Problem
RAMM0 memory range has already been F28069.cmd /dev_28069_Dec__6_v1/app line 30 C/C++ Problem
RAMM0 memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 30 C/C++ Problem
RAMM1 memory range has already been F28069.cmd /dev_28069_Dec__6_v1/app line 43 C/C++ Problem
RAMM1 memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 43 C/C++ Problem
RESET memory range has already been F28069.cmd /dev_28069_Dec__6_v1/app line 33 C/C++ Problem
RESET memory range overlaps existing F28069.cmd /dev_28069_Dec__6_v1/app line 33 C/C++ Problem
ROM memory range overlaps existing memory F28069.cmd /dev_28069_Dec__6_v1/app line 32 C/C++ Problem
