I’m currently configuring an RT Box–based HIL system that includes four flying capacitor boost converters.
As shown in the attached file, the system is structured in a master–slave configuration, where two flying capacitor boost converters are implemented per RT Box, and multiple RT Boxes are operated in parallel.
For the parallel connection between RT Boxes, we are using device coupling.
In this configuration, one side of the parallel connection is intended to behave as a current source, while the opposite side is configured to behave as a voltage source, in accordance with the general requirements for stable parallel operation.
However, we are encountering the following issue:
The model builds successfully without any errors.
But, when PWM signals are applied to the converters, all RT Box panels immediately report the warning: “Arithmetic overflow in FlexArray solver”
This warning appears consistently across all RT Boxes as soon as PWM switching is enabled.
At this stage, we would like to ask:
Whether there are specific modeling constraints or recommended practices for parallel RT Box configurations with switching converters
If there are any known limitations or additional requirements (e.g., impedance modeling, coupling strategy, or control assumptions) that must be satisfied to avoid FlexArray solver overflow in this type of setup
Relevant schematic files and configuration details are attached for reference.
We would appreciate your guidance on how this system should be modeled or configured to avoid the observed solver overflow issue.
Thank you very much for your support.
HV_BBU_Dual_RT_Box_wy.plecs (241.2 KB)
