Problems with CAN code generation
My model includes a part related to CAN communication. At the beginning, I generated the code and successfully debugged it on the board. However, after some time, when I flashed the code to the board again, the CAN communication would have issues and would not work properly. During this period, I didn’t make any changes to the CAN communication part. I have encountered similar problems multiple times. The way to solve this problem is to copy the CAN-related part to another model, flash that other model to the board, and then the CAN communication works fine.
What could be the reason for this?
Hi yuhangzhou, if you could attach a model to reproduce the issue that would be very helpful. Also please provide:
  • the TSP and PLECS versions you are utilizing
  • the board you are using
  • any other instructions that would be useful in recreating the issue
