Processing Bitstream from Delta-Sigma ADCs
Dear Concerned,
I am currently working on a design that uses delta-sigma ADCs for measuring different voltage and current signals. These ADCs provide a digital bitstream output, which is currently fed to a DSP for further processing.
I would like to know whether there is any possibility of filtering or converting this bitstream directly at the RT-BOX side before further processing. The reason for this requirement is that the measurement signals are highly sensitive, and we want to perform the signal conversion as close as possible to the measurement source while transferring the processed digital data to the DSP.
Could you please advise if the RT-BOX supports any method for handling delta-sigma ADC bitstreams, such as digital filtering or demodulation?
Thank you for your support.
Thanks & Regards,
Sanket Nalawade
