ZOH and sensing issue by using plecs
For the dab simulation, i caught the issue of unbalanced current.
As it used zoh for input voltage(which has a ripple value), it introduced the unbalanced current, as shown in the picture.
so how to configure the zoh application,
![Screenshot 2025-05-21 at 8.37.34 AM|690x432]
(upload://gXzRb3gX7GDHZhebmVehFEgbB83.png)
vg_sen is come from grid voltage.
zoh settings:
the PWM frequency is 100khz,
and simulation settings as:
how should I optimize the zoh setting to solve this issue.
thanks a lot.
There’s not enough information to debug your model. I cannot see a ZOH in any of your screenshots. Is one missing? How does the PFC PLL on vg_sen relate to the DAB current imbalance?
I will note that the PLL implementation can be sensitive to a DC offset, but it looks like you’re directly measuring vg_sen from an ideal AC source.
A model will be necessary for further guidance.
can i get your email adrress? then i can send you my simulation file which can not be opened here.
vfld_sens is the rectified voltage, which generates ripple voltage on it;
And it will go to the controller.
i doubted it, which updates the phase shift twice per cycle. coz i measured the phase shift value, it didn’t balance during the positive and negative parts.
how should i fix it?
thx a lot.
